I’ve started using cryptomator but I’m having trouble backing up using SyncBackPro.
As SyncBackPro starts with admin priviliges, and Cryptomator as a normal user. SyncBackPro does not see and cannot copy data from an unlocked Cryptomator drive.
I have read other related topics but these workarounds do not work for me.
I am currently mounting the drive as a directory in the location:
D:\Magazyn
In SyncBackPro I set:
As you can see the program can see the files but when I start the profile an error pops up.
I had troubles too. What worked for me is to sync the sub-folders within the Cryptomator folder. So instead of setting the source in Syncback Pro to D:\Magazyn\ you set the source to D:\Magazyn\Android. It means having multiple Syncback Pro profiles, but once they’re set up it worked for me.
