Hey all,
I use Cryptomator with Google Drive and Dropbox and I am very satisfied. But since Saturday, unfortunately, the Files app on the iPhone no longer syncs. Here is some info:
- Sync via desktop (Windows) works
- both cloud services do not work, the Files app only shows “Loading…”.
- a reinstall of Google Drive did nothing
- a reinstall of the Files app did nothing
- I have the feeling that the problem appears since my update to iOS 17. Can this be?
Do you have any ideas? Thank you very much in advance
