Symlink question
From release 1.4.3 it says symlink support experimental and take it as its now supported? Having tried to setup a link between a windows folder and encrypted folder.
On windows 7 I was able to set it up, but it does not sync or ‘work’, at all. On windows 10 (Using the general tool new-item) all I get is a “Cannot find drive. A drive with the name ‘J’ does not exist.”
Anyone else get it working?
Have a look at this issue on our bug tracker: https://github.com/cryptomator/cryptomator/issues/879
Symlinks do work, but to create one you need admin privileges, which make the vault not accessible (see also Drive not mounted for UAC Admin). You need to start Cryptomator with admin rights, unlock the wished vault and create a symlink via terminal.
