Symbolic link with source in mounted Cryptomator vault
I am trying to create a symbolic link with source directory in the mounted Cryptomator vault, drive letter for example is “L”.
When I try to create the link, I get the message: “Drive “L” is not available”. I am using WinFSP and Cryptomator 1.17.1
What can I do?
What if you were to mount Your Vault to a folder rather than a drive letter? That might make creating a link a lot easier.
I just mounted a vault on Drive e and created a symbolic link from a file inside the vault to a location outside the Vault and it worked fine.
Are you using the “mklink” command?
You need a /D if the link is going to be a directory rather than a file.
