Hi, how are you?
I was using the Cryptomator app successfully on Android for about 1 month. I made no changes to Android or Cryptomator or the login config. I also can access the same vault on Ubuntu with no problems. However, suddenly the Android app has stopped working in the following manner:
When I remove and add the existing WebDAV vault in Cryptomator, I select the master key file and see it fine (so it logs into WebDAV correctly). However, when I then see it in Cryptomator and click it to open the vault, it says “Vault not found” and that it has been renamed, moved or deleted - even though I just found it successfully and added it 2 seconds prior. I remove it and try again, but it’s just the same loop. This never happened before, all login details are unchanged, etc.
This is 1.5.18 from F-Droid … Android 10 / API29 on moto g(7) play
Here are some log entries:
I | 20210728114711.649 | App | Cryptomator v1.5.18 (2331) F-Droid Edition started on android 10 / API29 using a moto g(7) play |
I | 20210728114711.841 | Database | Configure v6 |
I | 20210728114711.842 | Database | Open v6 |
I | 20210728114711.943 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@d61991f |
I | 20210728114712.077 | App | Cryptors service connected |
I | 20210728114712.079 | App | Cryptors service connected |
I | 20210728114712.081 | App | Auto upload service connected |
I | 20210728114714.267 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.VaultListActivity@640f1a8 |
I | 20210728114716.882 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.ChooseCloudServiceActivity@ab3b2fd |
I | 20210728114748.326 | CryptorsService | ScreenLock received, destroying cryptors and shutting down service |
I | 20210728114753.825 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.ChooseCloudServiceActivity@ab3b2fd |
I | 20210728114756.324 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.CloudConnectionListActivity@6cfa1b3 |
I | 20210728114757.584 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.ChooseCloudServiceActivity@ab3b2fd |
I | 20210728114757.930 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.BrowseFilesActivity@743d268 |
I | 20210728114800.385 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.VaultListActivity@640f1a8 |
I | 20210728114835.254 | CryptorsService | ScreenLock received, destroying cryptors and shutting down service |
I | 20210728114855.510 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.VaultListActivity@640f1a8 |
I | 20210728114859.385 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@b9c18f2 |
I | 20210728115021.426 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@b9c18f2 |
I | 20210728115054.075 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@a789b54 |
I | 20210728115056.775 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@a13fc6b |
I | 20210728115103.252 | CryptorsService | ScreenLock received, destroying cryptors and shutting down service |
I | 20210728115103.495 | ActivityLifecycle | onResume org.cryptomator.presentation.ui.activity.SettingsActivity@a13fc6b |
Thank you for any help!
