Hello, I am a new user running Sierra.
Is it possible to force the WebDAV/volumes to be the same ones every time I mount and unmount them?
Currently they keep incrementing. For example:
- Create and mount new drive named “mydrive”
-volume is in path “volumes/mydrive-1” - Eject/unmount “mydrive”
- Mount “mydrive”
-volume is in path “volumes/mydrive-2”
I need either the WebDAV or the visable volume path to remain static across mounts so I can have other programs look in my drive.
Thanks for any help!!
