Spotlight (Mac) working with Cryptomator
Does spotify (Mac) shows files inside the vault when it is open ?
Can you clarify what you mean? Do you mean you use Spotify to play local audio files? I don’t use Spotify to play local audio files, but I would assume it should work perfectly fine with Cryptomator.
Thanks for the answer. My fault, I meant spotlight. With Boxcryptor, I can see the research’a answers even if I can’t open the file without the software activated. Can I see elements matching my request in the vault ? Thanks.
Ooh, I would assume spotlight wouldn’t index Cryptomator files when the vault is locked, though it might if the vault is open for long enough for spotlight to notice and scan it
Spotlight does not work with Cryptomator…or any network mounted drive to my knowledge. Perhaps that’s a feature for some… You can search in finder for file names when the vault is unlocked.
