I’m new to Cryptomator and couldn’t find a solution to my problem. Whenever I start Cryptomator I get the following error message: “The procedure entry point JVM_GetLastErrorString could not be located in the dynamic link library C:\Program Files\Java\jre1.8.0_202\bin\zip.dll.” When I confirm the message with OK (the only button), Cryptomator seems to start normally.
How can I prevent this error message and use Cryptomator without problems? I guess Cryptomator needs to use its own Java runtime located at “C:\Program Files\Cryptomator\runtime” instead of my installed version. How can I achieve that? I don’t like to uninstall / update Java, because it’s needed for other software.
I’m using Cryptomator version 1.5.11 under Windows 10 Education version 1909, 64 bit.
