I’m running Cryptomator on Arch Linux. It has been working properly until today. Not sure what changed, but instead of open the file manager, it is opening a search program I have installed called “Catfish”. I’ve checked inside Cryptomator settings, but don’t see any option there. Does anyone know how to correct this?
**I found reference to the issue in another question regarding an upgrade. I had to go into “default applications” and change “inode/directory” from Catfish to Thunar.
