Hello i am on MacOS 12.4 with latest cryptomator 1.6.10
When trying to unlock any of my vaults i get this error:
Error Code E5BN:E5BN:BIEF
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:58)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:45)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.Vault.unlock(Vault.java:153)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:72)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:62)
at org.cryptomator.desktop@1.6.10/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:35)
at javafx.graphics@18.0.1/javafx.concurrent.Task$TaskCallable.call(Task.java:1426)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: ru.serce.jnrfuse.FuseException: Unable to mount FS
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:46)
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
at org.cryptomator.desktop@1.6.10/org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:56)
… 12 more
at org.cryptomator.frontend.fuse@1.3.4/org.cryptomator.frontend.fuse.mount.AbstractMounter.lambda$mount$0(AbstractMounter.java:26)
… 1 more
… 2 more
