Slow Copy Speeds for Large Numbers of Folders
Hello.
I’ve seen many help posts about slow copy speeds, but since I couldn’t find a solution, I’m posting here.
When I copy 10,000 folders, each containing a single image (this is the structure of the image management app I use), to a mounted vault, the speed drops significantly to about 5 MB/s (it’s about 70 MB/s in a Veracrypt container). Also, when I access the folder containing the 10,000 folders, there’s a long loading time of about 5 seconds, and performance becomes sluggish. On the other hand, large files of 2 GB each copy at high speed.
Is Cryptomator not suitable for handling large numbers of folders and files?
My device has an NVMe SSD, the volume type is set to WinFsp, and the only antivirus software I use is Windows Security.
I do not use the cloud; I only use local storage.
Thank you for reading.
Did some testing.
Vault is on a HDD.
If I copy 10.000 folder with one 3 MB JPG file in each folder (29,2 GB) to the vault, it takes 6 minutes, 30 seconds. Thats an average of 76,7 MB/s
I also do not have a 5 second lag to list these 10k folders in the vault via the explorer.
Im afraid there’s something else that slows down your system.
So, your copying large amounts of data to an external SSD from where? Is it going from your computers internal drive to an external drive?
Or, are you copying the files from an unencrypted folder to an encrypted folder on the same hard drive?
I use and highy recommend an app called fastcopy windows only.
Fastcopy website
Windows file explorer is going to be a bottleneck for the transfer of 10,000 folders with a small file in each one.
Also windows robocopy is multi-threaded and a lot faster than using the regular copy command or File Explorer.
Now you have:
10,000 folders
files are 3 MB each
If there is one file per folder, total data becomes:
10000 \times 3\ \mathrm{MB} = 30000\ \mathrm{MB} \approx 30\ \mathrm{GB}
So now you’re dealing with about 30 GB total, but with a very high file/folder count relative to data size.
That means the bottleneck shifts from raw SSD throughput to:
filesystem metadata
directory creation
small-file overhead
antivirus scanning
encryption setup per file
Scenario 1
Internal SSD → external SSD
Even though 30 GB is small for SSDs, 10,000 folders slows things down.
Typical real-world speeds:
100–400 MB/s effective throughput
not because SSDs are slow
because many small operations dominate
Estimated time:
roughly 2–10 minutes
depending on:
antivirus
USB speed
folder depth
whether files are fragmented
Scenario 2
Same external SSD copy + encryption
This gets hit much harder now.
Why:
same SSD handling reads/writes
encryption overhead per small file
massive metadata churn
SSD random I/O instead of sequential
Effective speeds may drop to:
30–150 MB/s
Estimated time:
roughly 5–25 minutes
sometimes longer if encryption software handles each file separately
Small files are the real killer
A single 30 GB file might copy in under a minute on a fast NVMe SSD.
But:
10,000 small files
inside 10,000 folders
can easily take 10× longer.
Huge optimization trick
If possible:
1. Create one archive first using:
7-Zip
WinRAR
tar
2. Then encrypt/copy the archive.
This converts:
10,000 metadata operations into:
mostly sequential I/O
The speed difference can be enormous.
Example:
raw file copy: 15 minutes
archive then copy: 2–4 minutes
Best tools for this workload
For many small files:
FastCopy is usually excellent
Robocopy with multithreading:
robocopy source dest /E /MT:32
rclone also performs well with parallel transfers
Windows Explorer is often noticeably slower with huge folder counts.
