I have created a Cryptomator vault in OneDrive, i.e. with path
C:\Users\me\OneDrive\MyVault
This works great; using Windows File Explorer, I can right click the entire vault or any encrypted file in the vault and select the two OneDrive options: Always keep on this device and Free up space. I can also see which files are available locally and which are online-only in the Status column in File Explorer.
But of course, you can’t tell what any file actually is since they’re encrypted.
Is there a way to have these options available in the unlocked vault (i.e. E:\) too? Or at the very least show the cloud status?
From what I understand each file is encrypted individually in the encrypted vault’s d/ directory. Naively, I would think it possible that in the unlocked E:\ drive, you could query the matching encrypted file in the OneDrive folder for its cloud status.
