remy
May 26, 2022, 5:51pm
#1
Every time I open a vault, i get this error :
ERROR: ld.so: object 'lib/app/libjffi.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored
This is in a shell windows, and i can’t close the vault if I don’t close the shell before.
What can i do ?
I’m using Manajro
Thanks
How did you installed Cryptomator (AppImage, Flatpak, AUR (cryptomator or cryptomator-bin))?
remy
May 27, 2022, 10:59am
#3
I installed Cryptomator with AUR
Does installing AUR (en) - libjffi fixes this problem on your device?
remy
May 27, 2022, 2:23pm
#5
Ok it works, no error
Now the file explorer (nemo) opens directly on the directory that is allowed.
Is it possible to disable this function, it doesn’t happen with other Fuse mount points?
remy:
Hmm that is interesting
This is a vault option, see Vault Management — Cryptomator 1.6.0 documentation with the option “After successful unlock”
