Hi Development-Team,
with Cryptomator 1.7 you terminated the support for Dokany and you remmonended to use WinFsp instead.
I am sad about this, because there are serious compatibility differences to NTFS.
When I enter dir *docu*.* /s at the command prompt, the following results are shown on a NTFS volume:
Cryptomator Documentation.pdf
MyDocs<dir>
earlierdocs.docx
On a WinFsp volume, only earlierdocs.docx is shown as result, because search seems to be case-sensitive.
Is there a solution or workaround known for this issue, e.g. a mount option, that forces WinFSP to search case insensitive?
Thank you for tipps in advance.
Bfn
Michael
