Hello! May I ask about compatibility between RollBack Rx and Cryptomator?
I would like to avoid a possible conflict between these two programs and therefore decided to ask you in advance
I would be grateful for your help.
Cryptomator vaults are basically just a bunch of normal files like any other file on you system.
Althoug not having any experience with time-machine apps like RollBack Rx, I do not see why there should be any conflict when restoring a vault with such a backup solution.
