I… Accidentally deleted one whole family photos folder and I couldn’t find it in the recycling bin… Is there any way to get it back… Please…
have you synced your vault with a cloud storage? If yes, please if there is a recycle online. If there is one, restore every file that has the correct delete date. after that start your sync app, wait until the sync is done, and then open your vault again.
I didn’t… I was organising files and folder locally… Only after that I will drop it into cloud folder to sync…
If you do not have any other backup of your files, them I am afraid to say that I do not have any further ideas.
As far as I know there is no way to restore deleted files from a vault other than restoring it from a given backup (or the cloud recycle bin).
Omg…
this is painful…
