Hi there,
is there any possibility to remove vaults from the vault details page?
Except to restore the DB from Backup and remove everything linked to the given vault ![]()
Greetings
Malte
Hi there,
Greetings
Malte
Currently, this is not possible, but an archive feature is planned:
Thank you for the update
If you have access to the database you can delete the vault from Hub the following way:
docker exec -u postgres -it postgres /bin/bash or kubectl exec -it deployments/postgres -n NAMESPACE -- /bin/bash to the DB container.postgres://hub@postgres-hub:5432/hub. hub in front of the @ is the username, which is in the QUARKUS_DATASOURCE_USERNAME variable, but you probably shouldn’t have changed it, just in case. When the command is executed it will ask for a password, that’s the QUARKUS_DATASOURCE_PASSWORD variable. Both variables can be found in your depoyment file under hub and there environment.hub=> and we can enter SQL commandsSELECT * FROM vault; we can display all vaults. There we note the id of the vault we want to delete, for example 4e4362d1-8be2-4c5f-b4c3-bf2eacba1f1e
DELETE FROM vault WHERE id='4e4362d1-8be2-4c5f-b4c3-bf2eacba1f1e'; we can delete the vault with said id. This should be confirmed directly with DELETE 1
