Can I recover my vault with only the d folder, my password, and my recovery key?
More info: I created my vault. I tried to lock it, and I got a message that it could not ‘lock safely?’ or something like that. It seemed to be indicating that a file was still in use. After closing all applications, it still would not let me lock. So I just ‘force locked’ it.
Then, when I try to open the vault, it says, “cryptomator could not find a vault at this path.”
The path is correct. It has the “d” folder in it. But that’s all that is in there. No masterkey file, no vault file. I never deleted them. And there’s nothing in my trash bin.
Some steps I tried from a post I found here : Recover masterkey file with recovery key? - #3 by anon24105312
- Open new vault
- Copy that new vault’s files: “vault.cryptomator” and “masterkey.cryptomator”, into my original vault.
- Go into password reset for Old vault. Reset password
- Try password again.
Which didn’t work.
