I’d tried to open my Vault, but its empty. I get 2 files back, if someone could give me advice, it would be great, all my pictures are in this vault…
- File _Encrypt.check.txt
1 problem(s) found.
FATAL Exception java.lang.IllegalStateException: Required key length not supported.
at org.cryptomator.cryptolib.v1.Version1CryptorModule.assertRequiredKeyLengthIsAllowed(Version1CryptorModule.java:42)
at org.cryptomator.cryptolib.v1.Version1CryptorModule.provideCryptorProvider(Version1CryptorModule.java:35)
at org.cryptomator.cryptolib.v1.Version1CryptorModule_ProvideCryptorProviderFactory.get(Version1CryptorModule_ProvideCryptorProviderFactory.java:30)
at org.cryptomator.cryptolib.v1.Version1CryptorModule_ProvideCryptorProviderFactory.get(Version1CryptorModule_ProvideCryptorProviderFactory.java:10)
at org.cryptomator.cryptolib.DaggerCryptoLibComponent.version1(DaggerCryptoLibComponent.java:51)
at org.cryptomator.cryptolib.Cryptors.version1(Cryptors.java:27)
at org.cryptomator.sanitizer.CryptorHolder.bestGuessCryptorProvider(CryptorHolder.java:89)
at org.cryptomator.sanitizer.CryptorHolder.createCryptor(CryptorHolder.java:48)
at org.cryptomator.sanitizer.integrity.IntegrityCheck.check(IntegrityCheck.java:47)
at org.cryptomator.sanitizer.commands.CheckRunner.run(CheckRunner.java:60)
at org.cryptomator.sanitizer.commands.CheckCommand.run(CheckCommand.java:123)
at org.cryptomator.sanitizer.commands.Commands.run(Commands.java:75)
at org.cryptomator.sanitizer.Sanitizer.main(Sanitizer.java:16)
at java.util.Optional.ifPresent(Optional.java:159)
at org.cryptomator.sanitizer.Sanitizer.main(Sanitizer.java:12)
- File: _Encrypt.structure.txt
