I’m trying to copy from Google Drive (not encrypted) to a local Cryptomator vault (on an external hard drive) using Rclone copy command.
However, when running Rclone’s check command (after copying) it returns that almost 1/3 of the files are not on the external hard drive. But they are there.
I suspect that Rclone’s check command is running so quickly that Cryptomator cannot return file information.Just a guess.
I’m using Cryptomator 1.5.16 with Dokany.
Any suggestions?
