I have only 7MB (35 files) encrypted in one vault but I found out that the cryptomator background process uses up to 300MB of RAM. Sometimes more. Is this OK or do I have some problems or wrong settings?
Thanks!
I think, It’s normal… My encrypted Folder is about 35GB and the RAM-usage of Cryptomator is up to 320 MB too.
The App uses these resources, independend of data space, I assume.
OK - thanks a lot!
then I should encrypt more data to increase the RAM efficiency
