I am using version 1.11.0 (msi-4970) with “WinFsp (Local Drive)” (WinFsp 2023 2.0.23075). When trying to update a file in my vault, I get an “Access Denied” error. In my cryptomator0.log I see the following error for multiple files:
09:05:56.435 [Thread-21] ERROR o.c.frontend.fuse.ReadOnlyAdapter - read /Dokumente/Arbeit/[REDACTED]/.obsidian/appearance.json failed.
java.nio.channels.NonReadableChannelException: null
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.ch.AbstractFileChannel.assertReadable(AbstractFileChannel.java:102)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.ch.AbstractFileChannel.read(AbstractFileChannel.java:149)
at org.cryptomator.frontend.fuse@4.0.0-beta4/org.cryptomator.frontend.fuse.OpenFile.read(OpenFile.java:59)
at org.cryptomator.frontend.fuse@4.0.0-beta4/org.cryptomator.frontend.fuse.ReadOnlyFileHandler.read(ReadOnlyFileHandler.java:62)
at org.cryptomator.frontend.fuse@4.0.0-beta4/org.cryptomator.frontend.fuse.ReadOnlyAdapter.read(ReadOnlyAdapter.java:337)
at org.cryptomator.jfuse.api@0.6.3/org.cryptomator.jfuse.api.FuseOperationsDecorator.read(FuseOperationsDecorator.java:117)
at org.cryptomator.jfuse.win@0.6.3/org.cryptomator.jfuse.win.FuseImpl.read(FuseImpl.java:220)
I also see warnings like this:
08:52:18.418 [Thread-11] WARN o.c.frontend.fuse.ReadWriteAdapter - Setting posix permissions not supported by underlying file system.
and this error:
08:50:10.952 [Thread-20] ERROR o.c.frontend.fuse.ReadOnlyAdapter - getattr failed.
java.lang.IllegalStateException: Recursive update
at com.github.benmanes.caffeine/com.github.benmanes.caffeine.cache.BoundedLocalCache.doComputeIfAbsent(BoundedLocalCache.java:2666)
at com.github.benmanes.caffeine/com.github.benmanes.caffeine.cache.BoundedLocalCache.computeIfAbsent(BoundedLocalCache.java:2649)
at com.github.benmanes.caffeine/com.github.benmanes.caffeine.cache.LocalCache.computeIfAbsent(LocalCache.java:112)
at com.github.benmanes.caffeine/com.github.benmanes.caffeine.cache.LocalManualCache.get(LocalManualCache.java:62)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.CryptoPathMapper.getCiphertextDir(CryptoPathMapper.java:161)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.CryptoPathMapper.getCiphertextFilePath(CryptoPathMapper.java:122)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.CryptoPathMapper.lambda$getCiphertextDir$0(CryptoPathMapper.java:163)
at com.github.benmanes.caffeine/com.github.benmanes.caffeine.cache.BoundedLocalCache.lambda$doComputeIfAbsent$14(BoundedLocalCache.java:2668)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.CryptoPathMapper.getCiphertextFileType(CryptoPathMapper.java:97)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.attr.AttributeProvider.readAttributes(AttributeProvider.java:40)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.CryptoFileSystemImpl.readAttributes(CryptoFileSystemImpl.java:255)
at org.cryptomator.cryptofs@2.6.7/org.cryptomator.cryptofs.CryptoFileSystemProvider.readAttributes(CryptoFileSystemProvider.java:296)
at java.base/java.nio.file.Files.readAttributes(Unknown Source)
at org.cryptomator.frontend.fuse@4.0.0-beta4/org.cryptomator.frontend.fuse.ReadOnlyAdapter.getattr(ReadOnlyAdapter.java:198)
at org.cryptomator.jfuse.api@0.6.3/org.cryptomator.jfuse.api.Fuse$MountProbeObserver.getattr(Fuse.java:210)
at org.cryptomator.jfuse.win@0.6.3/org.cryptomator.jfuse.win.FuseImpl.getattr(FuseImpl.java:174)
The underlying file system is NTFS, Windows 11 Enterprise. The folder is part of OneDrive (private, not “for business”).
The NTFS access rights are full access inside and outside the vault.
