Dear Cryptomator community, I am currently setting up a new computer with Ubuntu 25.04, thus the installation is quite fresh (and has of course been updated today). I have installed Cryptomator and am now trying to unlock my vault but am either prompted error code N05M:RI0E:RI0E or 6HCL:2GTN:615N. I looked up the respective instructions for both on github (Application Crash when opening a vault on Linux via FUSE (Ubuntu 20.10) · Issue #1370 · cryptomator/cryptomator · GitHub and Error N05M:RI0E:RI0E · cryptomator/cryptomator · Discussion #3460 · GitHub ) and tried to solve the issue by applying the proposed solutions but unfortunately none of them worked. Does anyone has a good idea how this issue could be solved? Thanks a lot for your support in advance!
Welcome to the Cryptomator Communtiy ![]()
if you open the vault options, are custom mount options activated? If yes, what are they?
You can also upload a log file.
- create a new vault with Cryptomator
- quit the app (do not forget the tray icon)
- Start Cryptomator from terminal and redirect input into a file
cryptomator > ~\cryptomator.log 2>&1
- Unlock the newly created vault
- Quit the app
Afterwards post the log file here.
Dear infeo, many thanks a lot for having a look on my issue. Regarding your questions:
- the vault options are the default ones
- The log (I hope it is the correct one) is as follows:
22:13:33.570 \[main\] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/test/.config/Cryptomator/settings.json
22:13:33.640 \[main\] INFO org.cryptomator.common.Environment - user.home: /home/test
22:13:33.640 \[main\] INFO org.cryptomator.common.Environment - java.library.path: :/app/Cryptomator/lib/app:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
22:13:33.640 \[main\] INFO org.cryptomator.common.Environment - user.language: de
22:13:33.640 \[main\] INFO org.cryptomator.common.Environment - user.region: null
22:13:33.640 \[main\] INFO org.cryptomator.common.Environment - logback.configurationFile: null
22:13:33.640 \[main\] INFO org.cryptomator.common.Environment - cryptomator.settingsPath: /home/test/.config/Cryptomator/settings.json:\~/.Cryptomator/settings.json
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.ipcSocketPath: /home/test/.config/Cryptomator/ipc.socket
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: null
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.windowsHelloKeychainPaths: null
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.p12Path: /home/test/.config/Cryptomator/key.p12
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.logDir: /home/test/.local/share/Cryptomator/logs
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.loopbackAlias: null
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.mountPointsDir: /home/test/.local/share/Cryptomator/mnt
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.minPwLength: null
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.appVersion: 1.17.1
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.buildNumber: flatpak-1
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.pluginDir: /home/test/.local/share/Cryptomator/plugins
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.showTrayIcon: true
22:13:33.641 \[main\] INFO org.cryptomator.common.Environment - cryptomator.disableUpdateCheck: true
22:13:33.641 \[main\] INFO o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.17.1 on Linux 6.14.0-32-generic (amd64)
22:13:33.656 \[main\] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket /home/test/.config/Cryptomator/ipc.socket
22:13:33.855 \[JavaFX Application Thread\] INFO o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 546ms
22:13:33.984 \[JavaFX Application Thread\] ERROR o.purejava.appindicator.AppIndicator - Directory '/etc/ld.so.conf.d/' does not exist
22:13:33.985 \[JavaFX Application Thread\] INFO o.purejava.appindicator.AppIndicator - Native code library libayatana-appindicator3.so.1 failed to load
22:13:33.985 \[JavaFX Application Thread\] INFO o.purejava.appindicator.AppIndicator - Native code library libappindicator3 successfully loaded
22:13:34.348 \[JavaFX Application Thread\] INFO o.f.d.c.transports.TransportBuilder - Using transport dbus-java-transport-native-unixsocket for address unix:path=/run/flatpak/bus
22:13:34.371 \[JavaFX Application Thread\] INFO o.f.d.c.transports.TransportBuilder - Using transport dbus-java-transport-native-unixsocket for address unix:path=/run/flatpak/bus
22:13:34.377 \[JavaFX Application Thread\] INFO o.f.d.c.transports.TransportBuilder - Using transport dbus-java-transport-native-unixsocket for address unix:path=/run/flatpak/bus
22:13:35.933 \[App Scheduled Executor 01\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
22:13:47.058 \[JavaFX Application Thread\] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Test' failed.
22:13:47.059 \[JavaFX Application Thread\] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
java.nio.file.FileAlreadyExistsException: /home/test/.local/share/Cryptomator/mnt/Test
at java.base/sun.nio.fs.UnixFileSystemProvider.createDirectory(Unknown Source)
at java.base/java.nio.file.Files.createDirectory(Unknown Source)
at java.base/java.nio.file.Files.createAndCheckIsDirectory(Unknown Source)
at java.base/java.nio.file.Files.createDirectories(Unknown Source)
at org.cryptomator.desktop@1.17.1/org.cryptomator.common.mount.Mounter$SettledMounter.prepareMountPoint(Mounter.java:123)
at org.cryptomator.desktop@1.17.1/org.cryptomator.common.mount.Mounter$SettledMounter.prepare(Mounter.java:101)
at org.cryptomator.desktop@1.17.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:171)
at org.cryptomator.desktop@1.17.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:179)
at org.cryptomator.desktop@1.17.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:109)
at org.cryptomator.desktop@1.17.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:82)
at org.cryptomator.desktop@1.17.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:37)
at javafx.graphics@24.0.1/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
22:14:58.157 \[App Scheduled Executor 01\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
22:15:02.575 \[App Scheduled Executor 02\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
As the error message indicates, a file at /home/test/.local/share/Cryptomator/mnt/Test already exists. You need to delete this file first before mounting.
Dear infeo, thanks a lot, I have given it another try:
15:10:04.113 \[main\] INFO o.c.common.settings.SettingsProvider - Settings loaded from /home/test/.config/Cryptomator/settings.json
15:10:04.193 \[main\] INFO org.cryptomator.common.Environment - user.home: /home/test
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - java.library.path: :/app/Cryptomator/lib/app:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - user.language: de
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - user.region: null
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - logback.configurationFile: null
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.settingsPath: /home/test/.config/Cryptomator/settings.json:\~/.Cryptomator/settings.json
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.ipcSocketPath: /home/test/.config/Cryptomator/ipc.socket
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.keychainPaths: null
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.integrationsWin.windowsHelloKeychainPaths: null
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.p12Path: /home/test/.config/Cryptomator/key.p12
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.logDir: /home/test/.local/share/Cryptomator/logs
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.loopbackAlias: null
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.mountPointsDir: /home/test/.local/share/Cryptomator/mnt
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.minPwLength: null
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.appVersion: 1.17.1
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.buildNumber: flatpak-1
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.pluginDir: /home/test/.local/share/Cryptomator/plugins
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.showTrayIcon: true
15:10:04.194 \[main\] INFO org.cryptomator.common.Environment - cryptomator.disableUpdateCheck: true
15:10:04.194 \[main\] INFO o.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.17.1 on Linux 6.14.0-32-generic (amd64)
15:10:04.211 \[main\] INFO org.cryptomator.ipc.Server - Spawning IPC server listening on socket /home/test/.config/Cryptomator/ipc.socket
15:10:04.677 \[JavaFX Application Thread\] INFO o.cryptomator.launcher.Cryptomator - JavaFX runtime started after 871ms
15:10:04.868 \[JavaFX Application Thread\] ERROR o.purejava.appindicator.AppIndicator - Directory '/etc/ld.so.conf.d/' does not exist
15:10:04.869 \[JavaFX Application Thread\] INFO o.purejava.appindicator.AppIndicator - Native code library libayatana-appindicator3.so.1 failed to load
15:10:04.869 \[JavaFX Application Thread\] INFO o.purejava.appindicator.AppIndicator - Native code library libappindicator3 successfully loaded
15:10:05.251 \[JavaFX Application Thread\] INFO o.f.d.c.transports.TransportBuilder - Using transport dbus-java-transport-native-unixsocket for address unix:path=/run/flatpak/bus
15:10:05.275 \[JavaFX Application Thread\] INFO o.f.d.c.transports.TransportBuilder - Using transport dbus-java-transport-native-unixsocket for address unix:path=/run/flatpak/bus
15:10:05.281 \[JavaFX Application Thread\] INFO o.f.d.c.transports.TransportBuilder - Using transport dbus-java-transport-native-unixsocket for address unix:path=/run/flatpak/bus
15:10:06.797 \[App Scheduled Executor 02\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
15:10:36.295 \[JavaFX Application Thread\] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Test' failed.
15:10:36.296 \[JavaFX Application Thread\] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
org.cryptomator.integrations.mount.MountFailedException: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.frontend.fuse@5.0.5/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:137)
at org.cryptomator.desktop@1.17.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:172)
Caused by: org.cryptomator.jfuse.api.FuseMountFailedException: fuse_mount failed
at org.cryptomator.jfuse.linux.amd64@0.7.3/org.cryptomator.jfuse.linux.amd64.FuseImpl.mount(FuseImpl.java:33)
at org.cryptomator.jfuse.api@0.7.3/org.cryptomator.jfuse.api.Fuse.mount(Fuse.java:126)
at org.cryptomator.frontend.fuse@5.0.5/org.cryptomator.frontend.fuse.mount.LinuxFuseMountProvider$LinuxFuseMountBuilder.mount(LinuxFuseMountProvider.java:134)
... 12 common frames omitted
15:12:08.485 \[JavaFX Application Thread\] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Cryptomator' failed.
15:12:08.486 \[JavaFX Application Thread\] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
15:12:37.903 \[App Scheduled Executor 01\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
15:13:06.570 \[App Scheduled Executor 01\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
15:13:20.089 \[App Background Thread 006\] INFO o.c.u.a.CreateNewVaultPasswordController - Created vault at /home/test/Schreibtisch/Test2
15:13:21.096 \[App Scheduled Executor 01\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
15:13:23.533 \[App Scheduled Executor 02\] INFO o.c.common.settings.SettingsProvider - Settings saved to /home/test/.config/Cryptomator/settings.json
15:14:49.370 \[JavaFX Application Thread\] INFO o.c.ui.unlock.UnlockWorkflow - Unlock of 'Test2' failed.
15:14:49.370 \[JavaFX Application Thread\] ERROR o.c.ui.unlock.UnlockWorkflow - Unlock failed for technical reasons.
