Problems changing file permissions in the encrypted container
Hello everyone,
I have a problem when changing the permissions of files in the encrypted container of Cryptomator. Specifically, I want to change the permissions for a file and remove two users. However, when I make these changes and apply the settings, the removed users are added again.
I have also noticed that the encrypted data is running under different user permissions than the unencrypted file in the container.
FYI: I am using Windows 11 and Cryptomator version 1.14.2. The vault settings are otherwise default, except for the drive type which is set to “WinFsp (Local Drive)”.
Does anyone have any idea what this could be? I look forward to your help.
Many thanks in advance!
unfortunately, Cryptomator does not support individual file permissions inside a vault.
