Hi, im using the Desktop App and a Android App with Sync Tresor over Google Drive. When i put something in on the Desktop, i dont see it on my Android Device. Whats the Problem here?
Hi. Was the sync of the vault files from your desktop to google drive processed completely? If you do not see files on android that you see on your desktop, the reason is often that the sync between desktop and online storage was not completed.
Where do i see the proceed?
In your google drive sync client.
Oh true. My Sinc app wasnt active xD thanks
Thanks! I had the same problem
