PowerPoint files can't be read from vaults
Hello. I use cryptomator on a few windows based desktops (some run Win 10 others 11). Starting few weeks ago, when tried to open MS PPT, got error from PPT that can not read the file. All other files (including Word and Excel) work fine. I can move files from and into the encrypted drive–just can’t open directly. When first started, I installed new version of Cryptomator on all and it resolved. Returned yesterday; still newest version.
Many of the under the hood features of cryptomator are over my head. But, to the extent it’s helpful, I use WebDAV(Windows Explorer).
I seem to be able to work around this by moving files in and out. But, as I use PPTs frequently (teacher), hoping to find a true resolution.
Thanks for time and any advice.
I had the same problem appear suddenly early 2025, and for me the solution was to go in the settings of cryptomator (gear icon in the main app window), and switch away from "WebDav " to “WinFsp (Local Drive),” in the “Virtual Drive” tab. Everything else remains the same, but I can now open Office files directly like before. Hope that works for you!
Best,
