Hi, does anybody know how I can access an encrypted vault in OneDrive‘s Personal Vault with the Cryptomator iOS app? In my app the Personal Vault directory is not visible, thus I can‘t open it with the app. Thanks for any help.
I have the Android app and in that environment the answer is no. You can only put an access files in your main OneDrive area. Your files will be encrypted so there’s no issue with them being in the main area. If you try and use the personal Vault you might discover the size is very small.
