It looks like the problem takes place directly in the authentication as we don’t return to Cryptomator authenticated. The authentication itself is done in a browser (WebView) where the oauth login screen of pCloud is called and there their code is executed, unfortunately we therefore don’t see in the log what exactly goes wrong, only that you didn’t return to the cryptomator app authenticated.
I just tried to reproduce it again and the authentication works for me (to rule out a general error). Do you have any special account, VPN active which blocks some sites, …? Maybe you can also create a test account and try it with that (luckily they offer free accounts)? That could definitely help us.
I’ve created a new pCloud account using different log-in details. This new account I can connect to with Cryptomator. However when I try to create a new vault I get the (rather unhelpful) message “An error has occurred” and no vault is created.
We’ve just released version 1.5.16 which solves your second issue @sts . F-Droid and Website is already online, Playstore is waiting on the review of Google but will be ready for update in around a day or so…thanks again for reporting and thanks to @sToRmInG for the quick fix
Hmm, I switched from Google Play version to F-Droid version (1.5.16). Now I cannot login to pCloud anymore. I removed the cloud and tried to reauthenticate. Does not work.
Hi there, i was trying to make vault on my android cryptomator to Pcloud and sign in using Gmail. but it said Error 403:disallowed_useragent “Google can’t sign you in safely inside this app. You can use Google sign-in by visiting this app’s website in a browser like Safari or Chrome” what should i do to fix this? thank you.
As much as I love Cryptomator, especially for other cloud systems. I think in this case regarding pCloud, zero-knowledge E2EE and Android access, its probably better to concede and buy pCloud Crypto Vault. I use it and have zero problems with it both on desktop and via Android.
Bear in mind that pCloud’s concept is to download a file from the Crypto Vault, edit it, then upload it again. But I don’t have any issues previewing files in my Crypto Vault on Android.
