Hello, I want to integrate a cryptomator folder, stored on a USB-Stick and plugged in as an OTG Stick in my android 7 mobile phone. Unfortunately I can copy the folder with the help of explorer software to the phone but can´t open or integrate the folder on the usb Stick directly in the cryptomator app. Does anybody knows a propper way to do this? Many thanks for your help and ideas says
Detlef from Germany
Following this tutorial, you should be able to access Cryptomator vaults stored on external devices like USB flash drives: How to get access to a vault stored on external device like SD card
@Jeff_K_Daniel is that what you mean by “bootable pendrive”?
