When I use Cryptomator and Fuse on my Macbook and I restart the computer, FUSE creates always new volume names, which are like that:
drwx------ 1 user staff 0 1 Jan 1970 pLFnDod-SjCN_0
drwx------ 1 user staff 0 1 Jan 1970 vm19L1w0SfT1_0
When I use WebDav it is always the same volume name and I can use links on my desktop to access the drives:
drwx------ 1 user staff 2048 27 Apr 13:59 Data
How can I set or force Fuse to use always the same names for the volumes or maybe custom volume names?
I need to use Fuse, as I always have problems with large files (e.g. 5GB) with WebDav.
And I need shortcuts on my desktop, as I access all my data with Cryptomator in the Cloud.
Thank you
