I created vault using 1.4.0 sometime end of the last year. recently, i verified with 1.4.9 and works fine 1month back.
Yesterday, i updated OS to Mojave 10.14.4 and updated OSXfuse to 3.9.0
Now, i am not able to open my encrypted storage from cryptomator 1.4.0, 1.4.9 and 1.4.10 apps.
Please help me, below is the log:
12:35:30.946 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.10 on Mac OS X 10.14.4 (x86_64)
12:35:31.010 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
12:35:31.184 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
12:35:31.241 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded libMacFunctions.dylib
12:35:32.417 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.10, lastest version: 1.4.9
12:35:40.959 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
org.cryptomator.ui.model.Volume$VolumeException: Unable to mount Filesystem
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:105)
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:56)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:113)
at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:439)
at org.cryptomator.frontend.fuse.mount.AbstractMount.mount(AbstractMount.java:25)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:32)
at org.cryptomator.ui.model.FuseVolume.mount(FuseVolume.java:103)
... 12 common frames omitted
at ru.serce.jnrfuse.AbstractFuseFS.mount(AbstractFuseFS.java:281)
at org.cryptomator.frontend.fuse.mount.AbstractMount.mount(AbstractMount.java:23)
... 14 common frames omitted
at ru.serce.jnrfuse.AbstractFuseFS.mount(AbstractFuseFS.java:277)
... 15 common frames omitted
12:35:42.595 [Thread-0] INFO o.c.launcher.CleanShutdownPerformer - Goodbye.
