at org.cryptomator.common.vaults.Vault.unlock(Vault.java:142)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:48)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:8)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:50)
… 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:46)
… 14 more
… 15 more
Pretty limited information you provided but maybe this will help:
