org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 67 has occurred
Hi
I am unable to connect to OneDrive with the error msg as follows:
org.cryptomator.common.vaults.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 67 has occurred.
The network name cannot be found.
at org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:86)
at org.cryptomator.common.vaults.WebDavVolume.mount(WebDavVolume.java:48)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 2. Expected 0. Stderr: System error 67 has occurred.
at org.cryptomator.common.vaults.WebDavVolume.mountServlet(WebDavVolume.java:84)
... 12 more
This is the first time I have encountered this issue
Thanks in advance!
