Hi, I used Cryptomator on Windows before and created some pretty large vaults using Dakony, but now switching to Arch Linux using it might have been a problem: I mounted a virtual drive from Google Drive using Rclone and as far as I can tell this experience is identical to that I got on Windows with Google’s Drive for Desktop (old Drive File Stream). I installed Cryptomator using the AUR but only after trying to open a vault and nothing happening I noticed that this Linux version can only create FUSE or WebDAV vaults.
Now, is it possible to “install” the Dokan Library and use it with Cryptomator on Linux or I’m doomed decrypting and re-encrypting a few TB’s of Dokany vaults?
Also, another question that came to mind: Is it possible to access FUSE vaults on Windows?
Thanks
