Hi guys, I am on Manjaro Linux and have 4 vaults on a nextcloud that are encrypted with cryptomator. Worked great for several years, but no one of my vaults won’t open anymore… the one with some actually important stuff for me…
That’s the error message I get:
org.cryptomator.common.vaults.Volume$VolumeException: Did not find feasible mount point.
at org.cryptomator.common.vaults.FuseVolume.chooseNonExistingTemporaryMountPoint(FuseVolume.java:96)
at org.cryptomator.common.vaults.FuseVolume.prepareTemporaryMountPoint(FuseVolume.java:73)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:55)
All other vaults open just fine. I also have some 3 masterkey.cryptomator.bkup files in my folder.
If I go to vault options I can create my recovery key by entering my password. (Don’t know if it would really work, but at least something is showing up)
Tried using the Appimage from the Website and the build from AUR, no lock with both.
