this may not be a total cryptomator problem, but it affects cryptomator
ANDROID phone, CRYPTOMATOR vault in ONeDrive.
PROBLEM, need to use this in OFFLINE mode. I TRIED setting OneDrive to OFFLINE FILES, but cryptomator does not SEE oneDrive Offiline files, and as i read through the forum, i see that you have to COPY the files to a local android filder.
OK, did that
Onedrive, CRYPTOMATOR vault FULL FOLDER, copy to ANDROID-MiscMyFiles-CRYPTOATOR folder.
then went to cryptomator, ADDED location, pointed to the LOCAL FOLDER on android phone.
I then went to OPEN the cryptomator vault, entered password, it UNLOKED it, but gave message of “EMPTY FILES” (or something like that)
I again did the COPY function, overwrote current local file, etc, etc.
same sceanariio, EMPTY FILES
I THEN hooked up my desktop PC to the android phone, USB cable, and did the copy function, from the ONEDRIVE same folder, to the local android cryptomator folder.
THAT time, it opened, and SHOWED THE CONTENTS !!
ISSUE-PROBLEM seems to be, in Android, when COPYING in the android, from a onedrive CRYPTOMATOR folder, to a local android CRYPTOMATOR folder, it is NOT COPYING all the contents, even though no error message comes up. I repeated this multiple times.
Any suggestions as to how to FORCE a full COPY of ONEDRIVE cryptomator folder, TO a local android CRYPTOMATOR folder, is appreciate3d.
I CAN hook up the desktop to force the copy, but that is a pai, because sometimes i do not have access to it, to do an update.
I use cryptomator to hold copies of wallet contents, keepass files, etc, for travel and security
any help appreciatd, thanks
