Hi there,
since I upatet to Ubuntu 22.04.2, It does not start.
Has anyone a Idea?
Hi there,
Has anyone a Idea?
I assume you are using an AppImage. So, right click on it, go to properties → permissions, and select Allow file to run as a program
. Then, try opening the AppImage again.
thats for sure. But it still doesn`t work.
Greetings
Try installing the PPA version then. Visit Cryptomator’s downloads page, and select Linux. You will see some links under the header Package Repositories
, one of them is a link to the PPA.
Did you ever get your cryptomator appimage working? Mine won’t work since updating to Debian 12.
Appimage working fine for me on debian 12. What error do you get?
Thanks for your reply!
When I attempt to run the latest cryptomator appimage in a brand new virgin Debian 12 container (nothing else installed, only did sudo apt update and sudo apt upgrade), then the GUI doesn’t launch and I get the following error:
I am using the x86 version, not the PPA version.
Out of curiosity,
