Cryptomator version: 1.6.17 (Mac OS)
my mount options: -ovolname="localdrive" -oatomic_o_trunc -oauto_xattr -oauto_cache -onoappledouble -odefault_permissions -ouid=501 -ogid=20 -oallow_other
I was able to reproduce the same error that was seen when running pipenv install
within a mounted cryptomator directory using this python test script below
# python test.py
from tempfile import NamedTemporaryFile
# /Users/asdf/abc is the mounted directory
f = NamedTemporaryFile(
dir=os.path.dirname("/Users/asdf/abc/xyz/Pipfile.lock"),
prefix=".__atomic-write",
mode='w',
encoding='utf-8',
newline='\n',
delete=False,
yields
Traceback (most recent call last):
File "/Users/asdf/xyz/./test.py", line 25, in <module>
File "/Users/asdf/.pyenv/versions/3.10.2/lib/python3.10/tempfile.py", line 553, in NamedTemporaryFile
(fd, name) = _mkstemp_inner(dir, prefix, suffix, flags, output_type)
File "/Users/asdf/.pyenv/versions/3.10.2/lib/python3.10/tempfile.py", line 256, in _mkstemp_inner
fd = _os.open(file, flags, 0o600)
FileNotFoundError: [Errno 2] No such file or directory: '/Users/asdf/localdrive/abc/.__atomic-writeer5aq2w0'
@tobihagemann im not sure who to tag but would you know? I’m trying to do dev work within an mounted directory located within my home directory. if i try running pipenv install
outside the mounted directory, it works fine, so it seems that the pipenv process doesn’t have permission to access the mounted directory even with the -oallow_other
mount option
