13:08:46.120 [Background Thread 3] WARN o.c.ui.model.UpgradeVersion5toX - Upgrade failed.
org.cryptomator.cryptofs.migration.api.NoApplicableMigratorException: null
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:97)
at org.cryptomator.ui.model.UpgradeVersion5toX.upgrade(UpgradeVersion5toX.java:45)
at org.cryptomator.ui.controllers.UpgradeController.lambda$upgrade$0(UpgradeController.java:128)
I already found this issue but it is of no help:
I have a folder “files.cryptomator” containing “masterkey.cryptomator” including backup and the files in single letter cryptic folders.
Hi Tobias,
thanks for your quick response. I was able to understand the relation between version from cryptomator file and official release version. Also I could use the upgrading support with an older version as an intermediate step (migrate to file version 5 and then finally with my recent version to 6) so I did not even have to put the unencrypted data on my disc temporary.
Now my data is now working with the recent version.
