After the update to 1.15.2, The cryptomator (desktop) is no longer working.
I have a vault, the directory is in the dropbox. After the update, I always get the message “No write access to vault directory: Cryptomator cannot write to the vault directory. You can change the vault to be read-only and try again. This option can be disabled in the vault options”. I can still read or copy the files, but no longer able to modify the files.
I tried all different volume types, none of them works at all. I even tried to uninstall and reinstall the app, also didn’t work.
The funny thing is, the mobile version of the Cryptomator which I paid for it, works perfectly and can add files to the same vault that doesn’t work using the desktop app. (So obviously a paid app is better than a free app).
I also tried to setup a new vault and set the storage location to the dropbox, but it says “no write access at the specified path”. I can still add or delete files in the dropbox directly without using the vault.
Please advice.
