No "Add Existing Vault" menu item on Kali Linux
Add New Vault works as expected, but Add Existing Vault is missing from the UI.
OS: Kali Purple (freshly installed and up to date)
Desktop Environment: XFCE
File System: btrfs
Cryptomator Path: ~/Apps
Cryptomator Version: 1.13.0 (appimage-5321)
Didn’t change any of Cryptomator’s default preferences.
Any help is greatly appreciated. Thank you in advance!
Same thing happens to me, I have tried changing window screens as it is displayed for an instant but then disappears and it’s not clickable.
Using Linux Mint, 1.13 appimage version, XFCE and setup must be pretty standard.
Is there a workaround?
Just found a workaround.
After activating the Add menu, you can highlight each item using the arrow keys. Press the up or down arrow key until New Vault is not highlighted and press Enter.
Add Existing Vault is where it should be. It’s just the height of the dropdown menu is incorrect under XFCE.
Thanks, that works.
BTW, the same happens to remove vault, but using arrow keys works as well.
We are close to release a new version of Cryptomator with an update to our GUI framework. You can download the current beta here: Release 1.14.0-beta2 · cryptomator/cryptomator · GitHub
Does this fix the problem?
I was looking if you found a fix as the same issue happens with another program.
I have updated cryptomator but it did not solve the issue.
It’s more likely to be XFCE issue.
What other program?
I installed the latest version using flatpak but same issue.
Bug report submitted: Xfce: some menu items are not visible · Issue #3635 · cryptomator/cryptomator · GitHub
