Hi everyone,
I feel like this might be a common query, but I couldnt find a definitive answer and I want to be sure.
Mac user (M4 MacBook Pro) and new to Cryptomator. Mac optimisation setting is switched off.
I’ve created a vault in iCloud Drive that contains everything I store in iCloud Drive. I also use Time Machine to backup the computer.
As I have Optimisation turned off, the Mac should keep a local copy of my iCloud vault somewhere (I’m not sure where). This local vault should be getting picked up by the Time Machine backup (I’ve checked, and it does).
Can I rely on being able to restore that vault from a Time Machine backup in order get access to all the files stored within it?
Thanks.
