My concern: secretly disappeared files
During my tests, I noticed that files that were renamed in the vault (for whatever reason, by a person or “the system”) disappeared in the virtual drive. The integrity check does not issue an error message.
So, such a situation takes place unnoticed!
I wish that such a situation would be recognized and that I would be able to restore renamed files. What are the options here?
我也有这个疑问。比如文件或文件夹被重命名后能不能正常访问,希望能得到解答。感谢…
Edited by moderation with translation:
I also have this question. For example, can files or folders be accessed properly after being renamed, I hope I can get an answer. Thanks…
ok, i can check this with:
*.c9r - (dir.c9r + dirid.c9r) = number-of-files-in-virtual-drive
but it would be nice if such a check runs automatically and a message appears if there is a difference between the number of encrypted files and files in the virtual drive.
PS:
Of course, the files cannot be counted all the time, but it would be nice if the integrity check had such a check option. For the files in the virtual drive, I would like a corresponding “error message” in the file list, for example:
my-document-1.doc
my-document-2.doc
readme.txt
[decrypt_ERROR_id_0815.007]
So you could see that a file cannot be displayed in the directory and you could then look for the cause. I think that would be better than the file just “disappearing”.
