Multiple connections to same cloud provider
I have two business and one personal Cryptomator vaults stored in separate Google Drive Accounts, and it’s very inconvenient to have to keep logging in and out of the respective Google accounts just to access them.
Is there a workaround for this, or could you please consider it as a feature request?
Thank you
C
There is an app for Android called RSAF. It stands for rclone storage access framwork. I get it from github. Might be on fdroid too but I’m not sure.
I use it with Cryptomator everyday to access two different google drives.
In rsaf you must enable in settings local storage access.
First step is to create a remote to Google with the account settings that you want to use.
Rsaf should be running in the background each time you want to use Cryptomator.
In Cryptomator you will choose local storage for your Vault that exists on the Google Drive. Then you will link it to the proper drive and folder using rsaf.
If you need help setting it up let me know and I will provide some more detailed instructions.
Thank you for the hint. I’ll have a look at it.
It’s a cool program I use it a few different ways. I have a PDF scanner that scans receipts and things into the app and they ask for extra money to upload to the cloud after you scan and I do it for free with this app.
