Hi there, I have using this Cryptomator to lock my local file quiet some time, all the while have no any issue.
I just done cut and paste my file into the locked drive. After completed, I found that the Crytomator is auto locked the drive, and I found that the masterkey.cryptomator file is missing.
How can I do to unlocking my drive now?
I have check recycle bin, the masterkey.cryptomator is not there, and I very confirmed that, the masterkey.cryptomator file is not deleted, but I can’t find it now.
If you can’t find your masterkey file anymore, and you do not have a backup of it where you can recover the masterkey from, but you do have a recovery key for that vault, you can try this to recreate your masterkey file from the recovery key.
If you do not have a recovery key for the vault, and you can’t find your masterkey anymore and you do not have a backup or your vault (which contains the masterkey), then your files in the vault cannot be decrypted anymore and are lost.
