Maximum vault size / WinFsp
Dear all,
I installed Cryptomator 1.9.1 on W10 and changed the volume type to “WinFsp”. Then I’ve created a new vault, which is located on my OneDrive (C:\Users\xxx\New_Vault).
Unfortunately the maximum size of the vault is limited to my free space on C:. This indicates that WebDAV is still active?
No. As your local onedrive storage is on drive C, your maximum available vault space is the free storage on C.
If you need more space, you’ll have to find another drive where you store your vault, and then include this path to your onedrive sync in the onedrive app.
Thanks. Penny has dropped…
