Masterkey in Encrypted Vault
After creating an encrypted vault on Google drive a masterkey.cryptomor file is also in the folder. Why is that there? If it is deleted I loose access to the vault
If you search in this community posts, this point has been answered. My answer might not be technically very correct, but, in short, that’s where your password is encrypted to help you decrypt the encrypted files. Nothing to worry about, the password is well encrypted.
Thank you for your prompt response. I feel more at ease
Thanks for the information. I searched and the issue was indeed discussed prior. Apologies
