Hello all, I’m noticing a weird problem on a vault in my external SSD.
When I unlock my drive, I notice that it’s over 50 GB smaller than when the drive is locked.
I know that encrypting files adds a little bit of space, but certainly not this much. What is going on? I have another vault on my PC, but the size disparity is not that large.
if you are worried, that some files disappeared from inside your vault, you can run the vault health check:
Lock the vault you want to check
Open the vault options
Click the “Start Health Check” button
Read the info screen carefully, confirm it and click next
Enter your vault password
Run all checks
Check results of level warning can be fixed. For example, a common problem are orphan directories, which can be reintegrated into the vault directory structure in the lost+founddirectory inside the vault by fixing the result.
If you have critical results, data is missing. This does not necessarily mean, that it is lost, only that the vault data is not present on the local machine. If this is not only a snyc issue, the data is lost.
