I am using a current Manjaro with Gnome. I have installed Cryptomator as a flatpak. My vault is not located locally on the hard disk, but centrally on my NAS. The folder is mounted via dav/afp/smb/nfs (I have already tried everything). Access is no problem in Nemo (file manager).
If I now want to add this existing vault on my NAS in Cryptomator, I cannot see any network folder or connect. I only have the option to select a vault locally. What can I do to solve my problem here?
mfg
Stefan
Please note, that Cryptomator does not support network storages which are integrated via the filemanager, because those do not mount the folder into the filesystem. Use davfs2 or similar tools instead.
