Hi folks,
on MacOS -> Settings -> icloud -> icloud drive options
Cryptomator was listed and activated. Which data ist written into icloud with this option enabled?
Thanks in advance!
Hi folks,
Thanks in advance!
iCloud is not used, unless you explicitly create a vault inside the Cryptomator subdirectory of iCloud Drive.
